hi i got the dual regulator switch for this model and fitted it and it worked fine now the customer says its stopped working the grill element is fine
is it possible the supply to the regulator is intermittent , a circuit diagram would be usefull if any one can help thanks john
Thanks Dave thats great i wondered if the door switch on the top oven could be the culprit , are there any known issues that cause the grill to fail
thanks again John
Hi again Dave i went back to it and checked the door switch it was ok then i tried turning the top oven regulator i noticed it coulld be turned slightly anti clockwise 11 o clock after that the grill worked could it be just that the oven knob was not fully off due to play in the knob or its a bad connection on the oven switch ?
the customer was happy to use it so we will see what happens thanks again John
