Popped in to look while passing but didn’t dismantle to look as customer said it went bang when they opened the door one day and now the door is floppy. I said I would just get a couple of springs and go back, little knowing that these springs are now fetching £15.74 + delivery each from Connect. 😯 . But now I see those bits of string are listed under the same model. So is it more likely that’s what I’ll need? And if I should find it’s the springs required after all, not the strings, is there a cheaper source?
What a rip-off. Makes me all the more inclined to recommend Beko.
Mike.
Haven’t got my main PC fired up Mike, I am setting of down your way in about an hour, family wedding in St Austell so tagging a couple of days on.
I think this is a Brandt under the skin though.
I have never fitted springs to these, only ever fitted the strings, always fit both sides at the same time.
