Hi all, wonder if you can help.
I have a DH93CX and am having problems with the fan oven function.
When using the normal oven, this operates properly, however when attmptong to use the fan oven, it never seens to get to temparature, however the oven temperature light does extinguish, implying that the oven has heated as expexted. The main fan doesnt always start either and is given a helping hand to start spinning where required. Even when this is done, the oven still seems to struggle with getting to desired temperature.
DOes anyone have any ideas what might be causing this ?
