Hi I have a H2O fault on a hotpoint dishwasher model number Fdef33121v serial number 310166977 the water valve is working and the air break turbine is spinning free and machine is filling with water then showing h20 fault I suspect wash pump motor any advice appreciated thanks in advance kai
Hi dave wires are good it doesn’t sound like the wash motor is syncing with drain pump when it starts when it starts turbine is running free and wires to it are ok
the turbine may be free but the turbine has a magnet on it that passes a reed switch with every revolution. this sw allows the computer to count the water in. Due to age these do go faulty. most common on is in the bosch (impellor jug)
still could be the timer but could just be a duff reed sw
