HOTPOINT DISHWASHER
  • #33763
    dna
    Hi i fitted a pcb to a a hotpoint dishwasher fdw70 and now it says error A09 can anyone tell me how to configure the pcb please
    thank you
    #239932
    loopey
    Re: HOTPOINT DISHWASHER
    software recognition error replace timer ? either wrong pcb or try taking pcb off then leave it half an hour and refit n some times works ..
    #239933
    dna
    Thank you but dont see how taking it off and putting it back on can cure this as the pcb/time ris brand new.
    Any Help!!!!!!!!
    #239934
    loopey
    well just try it , have done this a few times and its worked 🙂 the only other thing is the pcb may not be programed had that in the past ..
    #239935
    Assuming , of course you have ordered and fitted an EEprom?
    #239936
    kiddo66
    Dependant upon the date code you may have to carry out the following
    Fit the eeprom to the module and disconnect the small fourway orange plug.
    Switch on the machine for thirty seconds then switch off.
    Remove eeprom from board and refit orange wired plug to edge connector on module.
    Fire up the machine and hey presto it works.
    (this week anyway)
    #239937
    HotDog
    Then you do the okey cokey and you turn around
    #239938
    HotDog wrote:Then you do the okey cokey and you turn around
    Kiddo, are you saying after you do that it works without the eeprom even being there?
    #239939
    lerch
    Yes you remove eprom once fitted and it should work have check with a hotpoint engineer. 🙂
    #239940
    kiddo66
    Yup certain datecodes cant remeber which,you just use the eeprom to programme the power module(rather like this new smartcard thingy will work)
    It threw me first time i came across it and it can be a pig to do but works fine once up and running.
