Hotpoint Dishwasher BF71
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Dishwasher BF71
  • #85771
    ColinD
    Gents,
    Just thought I may be able to help other users of the above machine with my own recent experience.
    The machine went faulty with the program not finishing its cycle and the outlet pump running continuously. The display showed the oft-mentioned ‘F’ fault indication. On a later investigation session the pump had stopped but the ‘F’ indication remained.
    I found that the short flexible waste link pipe in the lower left front of the machine base was almost completely choked with debris. However, having unclipped and completely cleaned and refitted this pipe, the ‘F’ indication stubbornly remained.
    By experimentation and a little luck I then found that I was able to reset the microprocessor by simultaneously pressing all four program buttons (with the mains on). The displayed ‘F’ promptly disappeared and the correct program times were restored. The machine runs correct wash cycles once again.
    Kind regards, Colin Doman, Weston Turville, Bucks.
    #429511
    Re: Hotpoint Dishwasher BF71
    ColinD wrote:Gents,
    Will the fairer sex not benefit from this snippet of wisdom and luck also?
