Been called out to this dishwasher
Original fault was that it leaking badly from door area, replaced lower door seal, tested ok.
Called back leaking again same place – water is being pushed out past the ends of the new lower door seal??
Removed to workshop, no leaks on first 2 tests and then started leaking on 3rd test run and has leaked every time since.
Have tried to reduce amout of water coming in to the dishwasher by ajusting the water level switch with no sucess as the water level seems to be controlled by flow meter.
Any Ideas???????? 🙁
