The customer starts the machine on first button on left. It fills, washes, heats and empties and I think at that point that is when the second led from left starts flashing!
I posted the same message for the same machine in December 05.
The fault then was an open circuit in the heater
The machine is heating
From the codes: = (reading from left to right)
Led2=inlet valve
Earth fault on heater if it is an IRCA heater replace with the Bleckman, most of the prob,s were caused by the Irca tubular element going down to earth etc cuases all sorts of weird faults.
This Part number C00057684 is what I fitted in December 05
Cannot rember what it said on it but from what you say it should have been a Bleckman.
I’ll have to go back and see if this one has gone down to earth, did not think it would be the heater again as it has only been in the machine three months!
