hotpoint dishwasher BFI620
  • #22594
    sandysuds
    called out to a hotpoint bf1620 dishwasher.
    it drained for a minute then started to fill and started to spray then back to drain (first light from left flashing ) fixed that, leak from pump, now it drains for a minute , then starts to fill, no spray action ,then 2nd and 4th lights flash ,and it drains, have checked heating side etc but no joy , can anyone help?
    #195557
    sandysuds
    Re: hotpoint dishwasher bf1620
    on returning to this dishwasher ,it pumps for 1 min then fills starts to spray for 1min the the 2nd and 4th lights flash ,indicating the heating side ,changed heater ,no joy could the microswitch/pressure switch on main hose between base and the circulation pump be at fault , can any one help as i am baffled
    #195558
    sandysuds
    hi guy,s could this be the pressure sensor
    #195559
    sandysuds wrote:hi guy,s could this be the pressure sensor
    As far as I know from reading the ‘Error Codes’ the 2nd & 4th lights flashing indicates a Pressure switch fault?
    The pressure switch is very easy to access and test on this model, but it’s probably just crud in the pressure chamber or hose?
    #195560
    sandysuds
    Re: hotpoint dishwasher BFI620
    thanks for your reply martin, tried that but still cant get to the bottom of this ,starts ,drains for a min, starts to fill ,starts to spray for a min then 2nd and 4th light flashes,drains and stops,
    I THINK IM BEAT, CAN ANYONE HELP?
    #195561
    I think I’ve been taking the Error Codes too literally in this case Sandy as it only refers to a ‘Pressure Switch’ fault 😳
    I didn’t realise these machines do indeed have a ‘Pressure Sensor’ as you mentioned earlier. And as the main circulation pump runs for a few seconds before the error shows, then it must be the pressure sensor either faulty or the flow from the pump is restricted for some reason (impellor fault even?) 😕
    (Perhaps the “Known Error Codes” needs editing to include ‘Pressure Sensor’ as well as ‘Pressure switch’? 😕 )
    #195562
    sandysuds
    finally found the fault bad connector from the heater too the control board, ,thanks too everyone for advice
