hotpoint dishwasher df61
  • #24996
    suedehead1
    the base of the dishwasher is filling up with water and then the float puts the pump on if i empty the water out it works ok then fills up again i cant see where the water is leaking from because of restricted access can anyone give me any possible idea where it could be leaking from.
    thanks in advance
    #204103
    Re: hotpoint dishwasher df61
    Salt pot clamp ring’s always a good one, failing that motor seals.
    With both sides, door and panel under door removed you can see pretty much everywhere. With a dentist’s type mirror and torch you can check the circ pump seals run the machine till really hot as that is when the pump seals tend to leak.
    #204105
    suedehead1
    the salt pot clamp ring is it easily accessable
    #204106
    suedehead1 wrote:the salt pot clamp ring is it easily accessable
    Never had one leak, unless of course the stupid customer has loosend it. Cavity needs lifting to replace.
    #204107
    Last one I had leak was a split heater box.
    jrrepair_2000
    Have a look in the bottom of the tub for small pin holes due to a flaw in the metal. We have had two of these, one on a Bosch, the other on a Hotpoint. Leaks worse when it gets hot.
