Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint dishwasher dif16. First three leds
- This topic has 7 replies, 2 voices, and was last updated 14 years, 4 months ago by
keithwilliams.
December 7, 2011 at 10:10 am #66720
keithwilliams
ParticipantAm at this job now.
Machine runs throught drainout pauses then fills to level. As soon as level is reached it aborts and drains with the first 3 LEDs flashing. I can’t find it in code book so would appreciate it if someone knows.
I have checked heater for continuity and spray pump. I’ve removed door harness to check for wire breaks. The boardappears ok the heater realy solder joints ok. Have nipped up connectors and now need advice please.
Thanks. KeithDecember 7, 2011 at 10:37 am #365009iadom
ModeratorRe: Hotpoint dishwasher dif16. First three leds
They are HERE in the Error codes thread.
Faulty turbine alledgedly, similar to impellor jug fault on Bosch etc.
December 7, 2011 at 4:11 pm #365010keithwilliams
ParticipantRe: Hotpoint dishwasher dif16. First three leds
so basically yet another seized crappy pump. think id better start carrying one as a spare.
thanks.
p.s. browsing through thread whicjh is in no order on phone in poor reception, lifes too short. id far rather buy another book thats up to date.December 7, 2011 at 4:32 pm #365011iadom
Its not the pump, its the water inlet turbine, as used on countless other machines such as Whirlpool and Bosch.
Its built into the water inlet matrix like the whirlpool one, part number C00356546, only around £15.
The link I posted was direct to the relevant post in the error codes thread BTW. 😉
December 7, 2011 at 4:58 pm #365012keithwilliams
yes sorry misread your post. i do carry the impeller jugs for bosch. problem im having now is that the part number you quote doesn’t come up on masterpart site. i’ll have a hunt around.
December 7, 2011 at 5:27 pm #365013keithwilliams
tracked it down. its c00256546 not c00356546.thanks for the pointer though
keithDecember 7, 2011 at 9:38 pm #365014iadom
keithwilliams wrote:tracked it down. its c00256546 not c00356546.thanks for the pointer though
keith:clown: Sorry. 🙂
December 14, 2011 at 6:38 pm #365015keithwilliams
inlet matrix fitted and fault cured.
thanks for advice.
i’ll be soldering a reed switch into the old one to see what happens when i get a chance to try it.
keith -
