hotpoint dishwasher DWF50P ERROR codes
Home Forums Public Support Forums Help And Support Dishwasher Help Forum hotpoint dishwasher DWF50P ERROR codes
  • #8935
    anybody help me with the error codes onthe DWF50P, it starts washing and halfway through stops with water still in. The eco and fast light flashes along with the rinse aid light. Ta Dave
    #131203
    Re: hotpoint dishwasher DWF50P ERROR codes
    Can you think of the lights as 1 to 4 from the left and let us know which lights are flashing. There is no download on Hopoint’s web site for the user manual for this machine so I cannot identify the lights, and I am still waiting for my copy of the tech manual……….May be able to suggest what problem ‘could possibly’ be if you do as suggested.
    #131204
    clyde
    Dave 123 wrote:anybody help me with the error codes onthe DWF50P, it starts washing and halfway through stops with water still in. The eco and fast light flashes along with the rinse aid light. Ta Dave
    Eco and fast flashing is a time out draining, check your filters and outlet plumbing. It may be a blocked pump. Get an engineer if you are unsure of your abilities – if you have a look yourself pull the plug out first :zap:
    Clyde
    #131205
    Thanks clyde think your right about the pump, i emptied it of water, it started ok but stopped again when it should of drained the water have already done the filters. Will check it out myself to start with as my abilities are pretty reasonable will let you know what was wrong with it. Ta Dave
    #131206
    Thanks for the help found a small bit of plastic handle jammed in the pump. Thanks again Dave
