Hotpoint dishwasher error
  • #41253
    Minge
    Hi i have this FDW60 and what happens is the light delicate flashes. just before drying i think. the PCB has been changed due to blown tracks and the heater is working ok. Any ideas>?????? lite
    #269271
    Re: Hotpoint dishwasher error
    Hotpoint DWF 50 & DWM55 also FDW60 dishwashers
    Led 1 Intensive
    Led 2 Normal
    Led 3 Eco
    Led 4 Fast
    Led 5 Prewash
    Led 6 Delicate
    3…..Overflow (water in base)-Leak from water line
    4…..Solenoid valve fault -Inlet valve,connections
    5…..Thermistor circuit-Thermistor c/w timer
    6…..Timeout heating-NTC detached from casing
    3+4.Timeout draining-Pump connections,blockage,module
    4+5.Timeout filling-Tap off,Inlet valve,connections,timer,water turbine
    3+5.Circulation pump not working- pump,connections,capacitor,module
    3+5.Filters blocked-Mesh plate,filter or microfilter,pressure sensor
    1+4.Software recognition error-Timer not programmed,wrong keypad
    4+6.Heating circuit-heater,connections,module,relay
    3+4.Hardware version (timer)
    According to that the fault is heater related. 😕
