Thank you for reply Dave. I could understand if the heater circuit runs through the pressure switch, and if made, with low water, could cause the safety stat to operate. I cannot see from hotpoint parts diagram, a thermistor or where it would be placed to register temperature, so I’m unsure how the control board would know when correct temperature is reached, unless somehow it senses from the in line thermostat fixed along with the overheat safety cut out on heater assembly, ie drop in watts used??
