Hotpoint Dishwasher SDW60
  • #59286
    johnnyhoz
    Customer reported not heating but no error code showing, found connector burnt on the heater, reconnected but no power to heater, pressure switch checked out ok,
    Is there anything else in the circuit apart from the PCB?
    Regards
    John
    #337569
    suedehead1
    Re: Hotpoint Dishwasher SDW60
    no its the pcb.
    #337570
    johnnyhoz
    Thanks suedehead1
    #337571
    Had one not heating the other day. Bit100 card looked alright but opened up the relay and found contacts quite burnt. New relay sorted it.
    Mike.
    #337572
    johnnyhoz
    Hi Mike
    is the relay part of the pcb?
    John
    #337573
    Yes!
    #337574
    johnnyhoz wrote:Hi Mike
    John
    Yes and it only costs about £1.50.
    A black, or sometimes white, block about 20mm X 15mm x 15mm. Five legs go into the pcb. Easy to change with a small soldering iron.
    If you’re interested in broadening your skills, learn how to do this, it’s fun and very satisfying!
    Mike.
