hotpoint door boot wire
  • #60323
    anyone have any experience with late hotpoint door boot
    model BWM129
    boot is held on with a wire that looks to me you would need a special tool to refit. there are 2 loops in the wire to push ends together that then hook to each other
    can get it off easy enough but do not want to leave the customer with no machine if i cant get it back
    Re: hotpoint door boot wire
    Have a read of THIS
    #341742
    thanks
    bigkid
    Hi, The “Have a read of this” link is dead, anyone point me to the correct page.
    I have an Integrated Hotpoint BIW105w that needs the boot changing and it would be handy to see how this clip is fitted.
    Cheers
    Tony
    #341744
    garn
    Martin wrote:Have a read of THIS
    hi martin every time i click on a link i get this ooPs error 404
    of out on one this evening its a ind wm12x uk 2 different porthole sizes 2 different bands1 door boot with no detergent recovery and 1 with.
    is the set up the same with hotpoint BWM 129 model for future ref.
    Garn
    #341745
    to put it in a nutshell you need a pair of lonnose pliers with an angled end
    the clip had a wire with 2 loops near the end and at the end hooks. you squeeze the loops till the hooks latch but you can only do it through the door as the front does not come off
    try http://www.amazon.co.uk/HYPER-CLAW-UK-2 … 37&sr=1-19
    hope it helps
    Simon46
    Or B&q longnose angled pliers 😀
    #341747
    rolf
    Cable tie the two hoops first because there a swine to fit. It will take a few goes to get it to lock together but the cable ties hold it in place while you have a play at fitting it. Tilt it back 45deg to give yourself more room.
    #341748
    twicknix
    I can’t really tell you how much it really made a huge difference by taking the advice on using cable ties! It took literally a minute to clamp it with the aid of cable tie after an hour trying various ways of fitting the clamp on. It was a real bugger to fit then a lifeline of cable tie made things sweeter! I was laughing with happiness when it worked.
