hotpoint door interlocks
  • #98601
    mikehha
    can anyone tell me the difference between c00628818 and c00307442 they look the same
    #472995
    murv
    C00628818 Is a Bitron standard PTC lock used to replace the discontinued ITW ZV449 lock fitted to some machines on the door lock recall list.
    C00307442 Is a Bitron PTC door lock with an extra door sensing switch in series with the PTC
    Murv…
    #472996
    mikehha
    thank you murv ! can they be interchanged as I have a customer that has a door problem that another engineer has looked at and I think he has fitted the wrong one.
    #472997
    if you post all the commercial codes and model i can look up the correct one
    murv
    When a sensing lock is fitted to a non sensing model It will work without issue
    The sensing switch is used on some models to let the software know if the door is open or closed (without trying to lock it).
    Sensing locks are used on some wash dryers and washing machines to tell the customer the door is open without pulling up a door lock failure error.
    Murv…
