Hotpoint drier
  • #44429
    waters
    CTD80 gives error code F13.White spot thermostats replaced but still no heat and f13
    #280946
    Specialist01269
    Re: Hotpoint drier
    Hi: You replaced the stats & obviously checked the element for continuity.
    Have you replaced the NTC & checked the wiring back to the board?
    Andy.
    #280947
    waters
    Re: Hotpoint drier
    It only has the 2 thermostats and the heater.There is no ntc in the middle
    #280948
    helo_75
    then put a new heater in with s on it
    its an ntc problem
    #280949
    Re: Hotpoint drier
    waters wrote:It only has the 2 thermostats and the heater.There is no ntc in the middle
    What’s the serial no of the machine?…and I’ll give you the correct part no for the heater assy you need. 🙂
    #280950
    waters
    Re: Hotpoint drier
    SN 510070212
    9531357000
    #280951
    waters
    Re: Hotpoint drier
    do i replace the heater with the same with 2 stats or the one with 3
    #280952
    helo_75
    doesnt matter, but your supposed to put the one with 3 on
    #280953
    johnnyj
    Re: Hotpoint drier
    As Helo says change the heater, if the heater and stats have had a good soaking you will get various thermistor faults, i’ve had a few recalls just fitting the stats trying to keep the cost down only to go back and fit a heater assy, JJ
