Hotpoint drum pulley, possible to change? Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint drum pulley, possible to change? This topic has 4 replies, 3 voices, and was last updated 15 years, 11 months ago by eastlmark. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts May 4, 2010 at 8:11 am #54360 eastlmarkModerator Hotpoint WMD940G, is it possible to change the drum pulley without removing tub? May 4, 2010 at 9:03 am #319346 SteveATYParticipant Is it the normal 13mm hex centre bolt holding it all together? Is so there is probably room to ease the tub towards the front of the machine and get a long handled socket drive onto the bolt head. May 4, 2010 at 9:38 am #319347 iadomModerator Re: Hotpoint drum pulley, possible to change? I have done both the one with the hexagon and the one with the torx head with the drum in situ. Found it easier to remove the front panel which allowed the drum to be tilted forward for better access. Jim. May 4, 2010 at 5:53 pm #319348 eastlmarkModerator Re: Hotpoint drum pulley, possible to change? thanks, its a bolt type, are these cracking in vast numbers then? this one only 13 months old. May 4, 2010 at 6:07 pm #319349 iadomModerator Re: Hotpoint drum pulley, possible to change? Not had that many, mainly just coming loose and knocking. :rolls: Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
