hi guys im having trouble with a drum spider part number every time i order from connect wrong one. The one im getting through has a bigger shaft part number im using is c00117329 .Ihave heard there are two different types any ideas
I thought there was only the 35mm one available. If the spider needs to be changed you have to also renew the rear half tub for the 35mm shaft one. Whats wrong with the spider anyway?
Just re-use the spider unless the bearings are loose on the shaft. The seal does not have to seal against the shaft surface. one part of the seal turns with the shaft, the other stays still in the tub.
