Hotpoint dryer CTD80 wiring diagram
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint dryer CTD80 wiring diagram
  • #52022
    Bernie
    Would anybody have a wiring diagram for a Hotpoint dryer CTD80 as I have no heat, thought it was the stat kit this one has three stats and the middle one is open circuit, the one in the new kit is also open circuit so not the kit heater ok.
    Thanks Bernie
    #310338
    RickT
    Re: Hotpoint dryer CTD80 wiring diagram
    Possible heater relay or dry joint on module down on the right hand side.
    #310339
    Bernie
    Thanks for that RickT
    #310340
    helo_75
    nah, it would flash the dreaded f8
    personally, id be making sure the pump was working, and the float switch wasnt activated
    #310341
    A1_Domestics
    I’ve forwarded a little something for you …just in case.
    #310342
    Bernie
    Thanks to both of you and a second thanks to A1 for the email
    Very much appreciated
    Bernie
    #310343
    Bernie
    I haven’t been back to this yet going on Tuesday, I have just got a new thermostat kit (10703608) which has one-shot cut out, a cycling thermostat and an NTC, should I not get some sort of reading across this as both the one in the machine and the new one are open circuit
    Looking at the wiring diagram it shows the NTC as closed circuit.
    Bernie
    #310344
    Both NTC’s will be OK, check it for resistance not continuity. 😉
    It will vary with temperature but should be at least 1000Ω
    Bernie
    Thanks for that Jim
    #310346
    Hollytree_Technical
    Have just had a call about one of these with an “F10” error and would like to go armed.
    Can some one send me the info please and can any one tell me what the difference is between the 2 thermostat kits (what is the difference between the black and white thermistors and are they interchangeable)?
    Thank you
    Jem
    #310347
    F10 open circuit in heater common, possibly one shot failed due to bunged up condensor.
    Err, one is black (TOD). C00208299, the other is white(ELTH). C00208298, they are not interchangable, both come as a kit.
