hotpoint dryer dead
  • #51963
    abbots
    hi,
    CTD40
    completeley dead, no lights or fault codes.
    i checked all obvious things, door interlock, supply, wiring loom.
    power getting to the lower module but no output.
    does any one repair the power boards on these?
    I cant see anything on the EMW site about them.
    any info. would be appreciated.
    thanks
    john
    #310129
    franz
    Re: hotpoint dryer dead
    have you checked the stats – some of these machines are wired so that if the stats go o/c – then eveything else goes dead.
    Franz
    #310130
    abbots
    un fortunateley yes,
    new stats tried
    #310131
    helo_75
    emw do now repair he boards, tony told me’
    good point about the stats though, they take out the neutral rather than the live, so it fools you if you live test
    last on i had, incidentally that was totally dead was the top board, not the bottom
    #310132
    abbots
    cheers for that,
    i’ll give EMW a ring tommorrow.
    jk
