Hotpoint Dryer No Display
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint Dryer No Display
  • #94685
    Nathan.Gartland
    HI I have a Hotpoint TCHL73BRPUK and im not getting any display.
    I have checked the electrics and all is fine.
    I have changed the main PCB and this has not solved my issue. I have also changed the display board and still not powering up. I have check the circuit from the pcb to display board and the cable is fine, also getting 240v through the cable.
    Can anyone suggest a fix for this.
    Nathan
    #458002
    Re: Hotpoint Dryer No Display
    you say you have changed the main pcb but how ?
    these boards are blank when you get them and need to be programmed. so unless you bought the programmer and software then it wont work
    Nathan.Gartland
    I ordered it from my own supplier who gets the boards programmed.
    I am a domestic engineer
    #458004
    ok
    not sure what to suggest as have no relevant tech
    1 are you sure he has programmed the correct software for the Ind code ?
    2 what was initial fault or was that a blank display problem ?
    If you are a professional then why not apply for trade access as we can do a lot more with members such as provide tech info where available which we cant do on a public forum
