Hotpoint dryer starts when off,
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint dryer starts when off,
  • #92322
    pmb
    Just out of gaurantee so not many engineers have seen this model
    Tvfs83cgp(uk): with the knob turned to off user tells me the lights
    And buzzer will suddenly come on, It’s not done it for me.
    But I don’t doubt the user, suspect PCB
    Anyone come across this.
    #450952
    Re: Hotpoint dryer starts when off,
    Nothing wrong with the knob then, no spillages behind it or some such?
    #450953
    pmb
    Knob ok. It turns off ok, all lights off.
    #450954
    Just read this from manual, as you have not seen the fault it could be that your customer is mistaking these functions?
    9. When the END indicator light turns on, the programme has ended. The buzzer will beep 3 times to let you know that your programme is complete. Open the door, remove the laundry then clean the filter and replace it (see Care and maintenance)..
    If the clothes are not removed at the end of the cycle the automatic POST CREASE CARE action will, on those programmes with this feature, continue to rotate the drum intermittently for up to 10 hours to minimise creasing. The phase is stopped when the door is opened or when the knob is set to OFF
    10. Set the program knob to OFF to switch off the machine.
    11. Disconnect the dryer from the power supply.
    Automatic pre-post Anti Crease This is an automatic function which provides an anti crease treatment both before and after the drying programme. By periodically rotating the drum before the start of the drying cycle, when a delayed start is selected, the formation of creases is prevented. On certain programmes the drum also rotates periodically at the end of the drying cycle on. The phase is stopped when the door is opened or when the knob is set to OFF
    #450955
    I doubt a squirt of switch cleaner would have any effect but is sounds like contact is made intermittently with adjacent programs in that off position. But worth a try I suppose before changing the board. 🙁
