Hotpoint dryer Tcfs93bgp.9uk no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint dryer Tcfs93bgp.9uk no heat
  • #97135
    slyp98
    Hey all , looked at this no heat 220v to element but some kind of sensor is next to the normal 2 stats on the heater element , suspect this but no parts available ,,, anyone come across this ind code 61553329700
    #466258
    there is 2 stats and an NTC
    ntc part no item 558 c00307622
    stat kit see pic
    slyp98
    Cheers mate
    #466260
    slyp98
    More drama with this fitted the new ntc , the element heats now but so low you could put your hand on it , any other idea cheers k
    #466261
    slyp98
    So theres only .9 of an ohm travelling to the element , control board fault ?
    anyone have a part no ? Thanks Kieran
    #466262
    Power module is C00506545, two different smart cards .
    #466263
    slyp98 wrote:So theres only .9 of an ohm travelling to the element , control board fault ?
    what do you mean .9 ohms to element, measured from where to where ?
    sorry if its a bit late been away
    wilf
    is there continuity through both parts of the element? had one where one part of the element went o/c
    wilf
