hotpoint dryer tdc 32
Viewing 9 posts - 16 through 24 (of 24 total)
  • #421117
    adv
    Re: hotpoint dryer tdc 32
    150 degree is before 1999 so not wrong state kit as only 7 year old an was def green spot on originaly . mmm more thinkin in bed time for me
    #421118
    adv wrote:i did notice the clean filter light is on.
    Well there you GO 😀
    #421119
    Element is switched off for the short reverse tumble, I have changed several door frame stats, every single one for O/C, never had one stick closed.
    Have you actually changed the capacitor, its the first thing I would have done if everything is clean and clear, after that then I would suspect the timer is not switching the heater off, easily checked if you have a plug in digital meter.
    Easiest way to quickly check capacitor is to remove the lid and place one hand firmly on top of the drum then switch it on, if you can hold the drum with very little force then the capacitor is shot, it will be virtually impossible to hold the drum by hand if it is OK.
    The clean filter light should come on when the door is opened and the timer contacts are in a certain position, it is not linked to any stats it’s just a general warning or advice light.;)
    #421120
    adv
    o/c door state symptons are ? will this cause the heater states to over heat an blow after about 3 loads tho ?
    #421121
    adv
    Martin wrote:
    Well there you GO 😀
    it only comes on when open door. goes off when shut it and start prog
    #421122
    The clean filter light should come on, that is normal when the timer is in a certain position, I have never, ever seen a door frame stat cause an overheat situation, only no heat.
    Have you changed the capacitor yet?
    #421123
    adv
    ok going back thurs gona try a capacitor
    #421124
    adv
    well back to this guys and could easily stop drum by hand . so changed capacitor , and states again . front exhaust stat tested. get continuity , and timer cuts heat last 10 mins , so hears hoping this sorts it , will have kittens if she phones again . thanks for all the help . i sit an pray )
    #421125
    Amen!
