hotpoint dryer tdc62n
  • #24630
    deltra
    hi all. fault reported was no heat ❗ stats u/s (green spot),fitted new ones,everything worked ok 😀 got back home, customer rang saying no heat again.(stats blown again) any ideas most welcome(fan etc seems to be ok)
    #202718
    wilf
    Re: hotpoint dryer tdc62n
    stats in right side/not mixed up? green on the left I think
    wilf
    #202719
    Very likely to be the dryness module faulty, sounds like the heater relay on the module has stuck. Easy way to check is to replace the stats then check to see if the ‘drying’ light comes on as soon as you select a programme, or if it stays on during short reverse tumble. Not a cheap module and EMW & QER do not repair these. 😥
    Part number if required is 1702136, list price over £70 + vat. 😯
    Not sure if anyone has successfully replaced a heater relay on this type of board yet.
    PS. I assume you checked the condensor was clean. 😉
    #202720
    Capacitor failing under load?
    Simon46
    If it works once. Dryness module every time 🙁 . Getting popular.
    S.
    #202722
    deltra
    any diagrams etc. ❓ where is the module ❓ 😳
    #202723
    Module is top right, at the front, looking from the front. If you run the tests I suggested, you could even bypass the ‘one shot’ for a few minutes and if the drying light is on as soon as you select a programme and before you press start, or when it reverse tumbles then I would stake your life on it being the module.
    deltra
    fitted module 8) got 10 miles down the road, and shes on the phone 😳 not heating again ❓
    #202725
    bobokines
    I take it that you meggared the machine. A DTE element can cause this fault.
    Bob
    #202726
    bobokines
    sorry for repeated replies. Somethig wrong with the system here.
    Bob
    #202727
    That better, Bob? 😀
    I have yet to fit a module on one of these – Tykes tend to go “HOW MUCH?” and rush off to Comet……… 🙁
    deltra
    yep chris,thats what mine has done,so anyone in need of a dryness module 😡 ❓ (heater ok bob)
