hotpoint dw df21p
  • #55999
    AASWALES
    hi this dishwasher is taking about 4 hours to complete a wash , customer says that the dishes are clean when its finished any ideas would be great cheers alan
    #325879
    ServEng
    Re: hotpoint dw df21p
    have you seen it take 4 hours to complete? or are you taking the customers word for it also is it a new machine? which possible takes longer than her/his previous model?
    #325880
    DF21 has got to be at least 10 to 15 years old. 😉
    Poor fill rate due to faulty fill valve/safety pressure switch is one possibility. The rubber diaphragm in the valve deteriorates. I usually manage to repair the valve by splitting a bog standard fill valve and swapping the diaphragm etc over.
    A no heat fault on this would stop the machine mid cycle.
    It should fill three times and then kick into action in less than a couple of minutes.
