I have the above dw. I noticed leak on the outlet hose , a small hole which looks like it was caused by heat from a metal tubalur elemnt above . I touched this element and got mild zap. I replaced hose but know when the dw start to fill up with water afetr about 40 sec the main breakers is activated in the fused board.
I assuming that for the main breaker to pop there must be a main fault and i suspect the tubalur elemet which i think is the heating elemt.
Any advice greatlfully accepted .
Cheers
Kboy
