Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint dw model lft114
- This topic has 16 replies, 5 voices, and was last updated 14 years, 5 months ago by
adv.
November 8, 2011 at 9:12 pm #66168
adv
Participantpower goin into this but wont start programmer doesnt light up. thinkin pcb advice lads ta
November 8, 2011 at 10:00 pm #363330A1engineer
ParticipantRe: hotpoint dw model lft114
have a look for broken wires in door, take of door skin there is a thin bar running across inner door, behind that you will find 1 or more broken wires, could possibly have caused board fault but might just be wires.
Kev
November 8, 2011 at 10:09 pm #363331adv
hi mate didnt think the new type dw get broken wires these days as the wires dont usualy go were the door goes up and down ust to be very common on older models?
November 8, 2011 at 10:30 pm #363332iadom
ModeratorRe: hotpoint dw model lft114
This is an Indesit machine we are talking about, as Kev says, some of the wires in the door harness are very thin and break off under the rod going across the centre of the door.
There isn’t a standard dishwasher on the market were the wires don’t go up and down at some point. It would be very common on these but not many of them get to be ‘older models’ :rolls:
November 8, 2011 at 11:11 pm #363333adv
ok lads al have closer look ta
November 8, 2011 at 11:16 pm #363334adv
you no what a meen tho the new ones are usualy in a plastic cover , not like the old phillips and candy wrapped in tape am peace of rubber sheath ahh the good old days. crimping all they wires with a harness kit lol
November 12, 2011 at 7:47 am #363335johnnyj
Had a few of the console boards causing this and as the guys say the wiring getting stuck in the insulation and breaking also.
November 12, 2011 at 2:10 pm #363336adv
ta
November 12, 2011 at 3:08 pm #363337iadom
Did one yesterday, there are only a few wires in the door harness, a couple of normal thickness ones and six or seven of the feeble thin ones.
On this one both of the thick wires had snapped at the bottom. :rolls:
November 13, 2011 at 10:22 am #363338A1engineer
Participanthotpoint dw model lft114
adv wrote:hi mate didnt think the new type dw get broken wires these days as the wires dont usualy go were the door goes up and down ust to be very common on older models?
Sadly these are ineshit, been to loads of ” new” dw under warranty needing wiring repaired.This is very common and will no doubt get worse as they get older..
On the flip side its a nice eay job for us. 🙂
Most common complaint is ” not starting or dead” usually 1 or both of door lock wires snapped.
November 13, 2011 at 10:34 am #363339adv
thanks for reply
November 13, 2011 at 5:18 pm #363340keithwilliams
ive had this as well. unfortunately after spending ages soldering and heatshrinking a repair to about four wires i discovered that they must have shorted and blown the board.therefore id quickly splice and test then solder if ok.
December 1, 2011 at 8:03 am #363341adv
hi lads this dw a had a look at wires none broken . but started working again a moved harness up a bit , how the hell do you get to the pcb anyway at bottom.?took the 2 srews out of panel at bottom front but couldnt get the plastic cover off ? or does it come off help lads?
December 1, 2011 at 9:39 am #363342iadom
That still sounds like a harness fault, you need to remove all of the black tape covering the harness where it bends at the bottom, had several now with breaks there.
Cover prises off, with care of course. 😉
December 1, 2011 at 12:20 pm #363343adv
Ok what a pig ti get of joke
