Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › hotpoint dwf 35 cycle problems
- This topic has 10 replies, 3 voices, and was last updated 16 years, 5 months ago by
neil9710.
November 6, 2009 at 9:12 pm #49948
neil9710
Participantwhen i turn on my hotpoint dwf35 dishwasher the digital counter shows an excessive time and after it has run for half an hour seems to add more time to the cycle, all in all takes about 4 hours to complete and doesnt seem to get water hot either, any ideas before i tear it all down.
November 6, 2009 at 9:46 pm #302825Penguin45
ParticipantRe: hotpoint dwf 35 cycle problems
It’s a Bosch-based machine. A read of THIS THREAD will probably help you.
November 6, 2009 at 11:19 pm #302826neil9710
just had it all in bits and yep that bit was clogged up, cleaned it out put it back together but same problem, its as though it doubled every programme time. Could it be anything to do with water temp as is doesnt seem to be getting warm?
November 7, 2009 at 12:40 am #302827Penguin45
PCB – burnt out solder joint is a strong possibility. That said, the start time should be correct and adjust later.
November 7, 2009 at 9:04 am #302828neil9710
just tested the heater element and its open circuit, nearly fell off my chair when i saw how much the heater units cost. could be time to part ways!!
November 7, 2009 at 8:50 pm #302829neil9710
bit the bullet and orderd a heater unit, will let you know how i get on, wot a nightmare getting too and removing this unit.
November 7, 2009 at 9:07 pm #302830Penguin45
Can you post up all the numbers in the etched panel on the the top edge of the door? There might be a way to save you a few bob.
November 9, 2009 at 9:52 pm #302831neil9710
The etched panel doesnt seem to be there, not sure if its come unstuck at some part of its life, thought it would be a shame not to repair the washer as its never let me down and its had alot of work, not into this throw away society either, too many manufactures are happy to use cheaply made parts to produce low quality goods for the high street. Thanks for the offer though. Had to order a full heater unit, shame really as the element can be removed but cant seem to buy this as a separate peice.
November 9, 2009 at 10:41 pm #302832iadom
ModeratorRe: hotpoint dwf 35 cycle problems
Its etched into the top of the stainless steel inner door, it can’t ‘come away’. 😉
You need to get the door at the right angle, shining a torch on the top edge sometimes helps to make it visible, its more or less in the centre of the door above the latch.
November 13, 2009 at 8:22 pm #302833neil9710
Installed the new heater unit last night, switched on and the timer still showed 199 minuits, let the machine run a cycle so the timer had chance to learn a wash time. Now all the wash times are back to normal around 110 minuits and the water gets nice and hot. All is well thanks for the help. By the way found the engraved plate, how could you have saved me some money? Just for next time it plays up!
November 13, 2009 at 9:23 pm #302834Penguin45
Because one of them will work on the BSHcustomerservice.com site, allowing you to source the parts that way. You’re paying twice if you sdource through Indesit.
