hotpoint dwf 70
  • #25273
    johno1998
    the door light just keeps flashing and dishwaher dosent do anything any i ❓ deas anyone not been to the job yet
    #205146
    Re: hotpoint dwf 70
    Cannot see any reference to a ‘door light’ in the info I have. The picture of the console is not brilliant but there is no mention of a door light. The digital display should show error messages if a fault is detected.
    You could also try a reset, press & hold the Start/Reset button, display should show a line of dashes after two beeps.
    Also, admittedly stating the obvious, check the door switch. 🙂
    Re: hotpoint dwf 70
    johno1998 wrote:the door light just keeps flashing and dishwaher dosent do anything any
    Door switch? :con:
    I often ask customers to point the phone at the machine so I can take a look…. :rolls:
    #205148
    johno1998
    Re: hotpoint dwf 70
    Your right it hasnt got a door light on this model only the lcd display, which has DOOR flashing on it, tryed reset option no joy also changed switch still the same. ❓
    #205149
    Re: hotpoint dwf 70
    I will try and sort out a wiring diagram for you later today, may not be much help but you never know.
