Hotpoint DWF Fault codes
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint DWF Fault codes
  • #12863
    mikechris77
    I have a list of Fault conditions. If you have a fault email me michael.scanlan1@ntlworld.com with the error (which LED’s are on or flashing) I will tell you what they mean
    #151962
    Re: Hotpoint DWF Fault codes
    But it won’t tell you how to fix them 😉 .
    #151963
    mikechris77
    but knowing what the fault codes mean gives you the area to look at.
    #151964
    Allegedly……..
    #151965
    kevanali
    our machine stopped working completely, no lights at all. There is power to the pump, if i operate the water level microswitch manually the machine empties. So now when the machine is turned on there is no action at all and no lights on the front, my wife said she heard a ‘puff’
    (her words) and it stopped, she hears all sorts when she wants a new one!
    sounds like an element blowing perhaps, left my test meter at work so cant check that yet. Is there a reset button on these.
    kev
    #151966
    You have a DWF— ? The flood protection system is on a separate circuit which is live as long as the machine is plugged in. I cannot recommend that you operate it manually. If the controls are not lighting up at all, it would imply that some sort of control board has blown. Nasty.
    Power off if investigating further.
    kevanali
    Thanks penguin
    Just to confirm it is a DW30
    any idea what would cause such a fault
    cheers Kev
