HOTPOINT DWF30 DISHWASHER
  • #26997
    barryfast
    Hi all this Hotpoint DWF30 water is discharging from the out let pipe as its filling intermittently and then it stops the tablet is not dissolving but seems to be washing very slow any help please Barry ❓
    #212180
    comptonappliances
    Re: HOTPOINT DWF30 DISHWASHER
    HAD A VERY SIMILAR PROBLEM ON A BRAND NEW ZANUSSI CANT REMEMBER MODEL N0 BUT SAME SYMPTOMS AND I FOUND IT TO BE A FAULTY PRESSURE SWITCH…NO GTD’S BUT WORTH A TRY
    #212181
    burns
    Check the pipe to the sump from the left hand side (metering tank) prone to getting full of gunk and restricting the water flow.
    Same as the post re the Bosch machine recently.
    If you remove the plinth, you can pull the hose away and refit very easily.
