hotpoint dwf30 problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum hotpoint dwf30 problem
Viewing 6 posts - 16 through 21 (of 21 total)
  • #203612
    chrisbe
    Re: hotpoint dwf30 problem
    Could you please let me know how I reset it ?
    #203613
    Does that mean it is incorrect?
    I will get back to you later today, car in for service so a bit pushed ATM. 🙂
    #203614
    chrisbe
    From what you said earlier I can only assume yes.
    When I hold in buttons 1 & 3 nothing happens to light 2 , however light 1 stays on until I release both buttons. Then lights 1 & 3 flash.
    #203615
    TBH, I have never, ever used the test sequence on one of these, even forgot there was one until you mentioned it. 😯
    A check on the water flow from the spray arms and a megger or multimeter across the heater would be my next step. 😉
    #203616
    chrisbe
    Finally found the problem. I removed the control panel to expose the circuit boards and having removed them one of the relays had blown a massive hole in the board and one leg of the device had completely melted. Decided due to cost of replacement board and no guarantee that it wouldn’t do it again to buy a new dishwasher.
    Just like to thank you for all your assistance, it was greatly appreciated.
    iadom wrote: If the element is OK then it could be a PCB or wiring fault
    Pity, at least you found it eventually.
