hotpoint dwf31.no go.
  • #19602
    effzedarr
    htpt dwf31 d/washer,dead, i get mains voltage thro’ the on/off switch, but nowt else,no lights or displays 😥 .Could it be the main board?
    Any ideas much appreciated…… 8)
    #183805
    Flyman
    Re: hotpoint dwf31.no go.
    Possible open circuit wash pump. 😕
    #183806
    HotDog
    Sounds like board to me had same fault about ayear ago part number 1801875 iwas unable to run last error code so i went for board not a cheep job but very good machine 8)
    #183807
    Check your e-mails effzedarr, 😉
    Hotdog ( Cliff ) 😉 Thanks for that referral today, BTW the VTD belt tool you made is brilliant.
    HotDog
    glad to here your tool works well as my old wood work teacher used to say if you dont use it you will lose it
