Hotpoint DWF31N/17
  • #4940
    Albert
    Hi guys
    I’ve got one of these Hotpoint dishwashers not heating, the microswitch
    on the element is in o/c state. Is it necessary to replace the whole heater unit or is it possible to replace a component that holds microswitch in n/c state. If so, does anyone have a part number ‘cos I can only find number for heater unit.
    Tia
    #106548
    Dave_Conway
    Re: Hotpoint DWF31N/17
    Hi Albert.
    If I recall the microswitch should be o/c until the circulation of water activates it, the pressure pushes a diaghram behind the switch.
    If that part is faulty the a new heater unit is required, part number 1801924.
    Hope that helps.
    #106549
    Albert
    Thanx Dave,
    you’ve been a great help
    Cheers m8
