Re: hotpoint dwf32 dishwasher not fully draining
This is a Bosch based machine and so it has a sealed base, pump access is rather difficult requiring removal of door panel, lower plinth etc.
If the pump is faulty it will not drain out at all.
You can check the pump impellor from inside the tub. If you remove the filter and look down into the sump, at around 8,o’clock you will see a small ‘L’ shaped cover secured by a single torx screw. If you remove this you can access the pump impellor and the black rubber, non return valve, watch out for bits of glass when you put your fingers in there.
