Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint DWF33 Dishwasher – no lights
- This topic has 3 replies, 2 voices, and was last updated 20 years, 4 months ago by
MickGeorge.
December 1, 2005 at 5:30 pm #13741
MickGeorge
ParticipantHi guys
Just need bit of moral support on this one. The machine does not start up and there are no display lights up. I thought this was a doggy module connection in the start switch as it momentry switches on then off as you activate the on/off switch (6 connection) but went to fit new one today and is exactly the same so they must just use that connection to signal the module I suppose. Got both live and neut feed thru on/off switch so I assume this is a module fault.
There is no water in the base either so doen’t seem to be a float switch problem.
Have I missed something stupid or does that seem right to you folks? I have tried to put in to diagnostic mode but with no lights up it doesn’t want to know.
If I order the module does it come with set up instructions as my manual only goes up to DWF32 as I havn’t had to fit one of these before? If not does anybody know the set up code please?
I hate these new over complicated machines – give me the old timers, proper on/off switches, door switches and open base machines anytime!
Comments appreciated – thanks 🙂
December 1, 2005 at 7:27 pm #156415Flyman
ParticipantRe: Hotpoint DWF33 Dishwasher – no lights
Strange as it may seem but check for an open circuit wash motor 😕 😕 😕
December 2, 2005 at 9:42 am #156416MickGeorge
ParticipantThanks flyman – might go back and check that out as module cost is an arm and a leg, special order with connection and non returnable if it an’t the problem!
December 6, 2005 at 7:05 pm #156417MickGeorge
ParticipantBeen back and checked motor – that seems to be testing out ok – still think it maybe module but customer getting Hoptiont out under 5yr part warranty due to cost so unless she lets me know looks like I might never know the fault.
Thought I might have had a bit more response to this fault – just thought it might have been a bit more of a common fault that it appears to be. 😮
By the way does anybody know what the third pair of contacts do on the main on/off switch as they only make momentarily when you switch on or off?
Thanks 🙂
