Hotpoint DWF33 drawing 4.5kw at mid cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint DWF33 drawing 4.5kw at mid cycle
  • #78143
    dangerousdave2
    With energy consumption rising rapidly, I borrowed an instant read power use meter and started checking the household appliances.
    The Hotpoint Aquarius DWF33 dishwasher was drawing 4.5kw. I dont know for how long or at what point in the cycle. However, this seems excessive. Will a damaged heating element cause this?
    The machine works well otherwise and is very quiet.
    Thank you for your ideas…
    Seamy
    Re: Hotpoint DWF33 drawing 4.5kw at mid cycle
    Doesn’t sound right, thats 18 amps and it has a 13 amp fuse, shouldn’t the fuse have blown then.
    Element in any dishwasher is normally no more that 2KW.
    #404644
    dangerousdave2
    It doesnt trip the fuse, or blow fuses in the plug.
    The meter is attached to the mains supply, with a remote digital read out.
    It was reading 5.554 kw which is huge. The highest it was before was 3.1 kw with a 30+ year old oil filled radiator on. (That is going to be banished to the recycling centre.)
    When I turned the dishwasher off the reading was 0.9.. something!
    So, if it was 0.999, say 1 kw, then the dishwasher was drawing 4.554 kw.
    I did this three times and each time it went from 0.9.. to 5.554 and back again.
    I think 13 amp fuses blow instantly at about 20 amps and at about 15 continuous… but that is just an ill informed memory i have somewhere.
    The dishwasher was drawing at least 4.5kw. For how long and why, I dont know.
