Hotpoint DWF34 D/W
  • #48661
    Display stuck on 43 minutes on all programmes, just seems to pump out and stay at 43 mins. Any clues?
    #297298
    Re: Hotpoint DWF34 D/W
    Not sure what you’ve found so far but worth checking all the usual suspects (blockage in pressure chamber/transfer pipe, heater o/c and burnt relay terminal).
    Does the programme do a reset cycle OK?
    #297299
    Hi Martin,
    I don’t generally do dishwashers these days but this one is for a good customer for whom I service some pottery kilns. If it had been something that didn’t involve taking the whole thing apart I would have had a go. What do you mean by a reset cycle?
    #297300
    Phidom wrote:What do you mean by a reset cycle?
    With the machine up and running press and hold the 3rd and 5th programme buttons together for 3 seconds. That resets the programme and the display returns to Zero whilst the drain pump only runs for exactly 60 seconds before switching off!
    That procedure clears any screwed up memory settings within the programmer.
    HTH? 🙂
    #297301
    Thanks Martin. I didn’t know about that. :tup:
