Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint dwf34 dishwasher – humming noise, no draining :(
- This topic has 6 replies, 3 voices, and was last updated 17 years, 2 months ago by
Morsey.
January 15, 2009 at 10:08 pm #42632
Morsey
ParticipantHi,
As the topic suggests my hotpoint aquarius dishwasher dwf34 has stopped working.
A cycle got stuck on 1 min remaining:
The dishes are dirty, the soap has only partially been washed from the panel. If I try to drain the water I just get a humming noise, no pump action…
Does this suggest a pump has gone?
Thanks,
January 15, 2009 at 10:29 pm #274210iadom
ModeratorRe: Hotpoint dwf34 dishwasher – humming noise, no draining :
The good news is that what you have is actually a Bosch produced appliance, not the appalling Indesit rubbish now masquerading as Hotpoint.
You can access the pump impellor from inside the tub.
Remove all the filters, then get rid of as much water as you can by any means, (cups, towels etc)
At about 8, o’clock in the bottom of the sump you will find a single torx screw which secures an ‘L’ shaped cover. Remove this and you then have access to the pump impellor. Take care at this point and look out for pieces of glass or any other foreign body that may be stuck in the pump.Jim.
January 16, 2009 at 8:18 am #274211Morsey
ParticipantRe: Hotpoint dwf34 dishwasher – humming noise, no draining :
Brilliant – Thank you very much!
I couldn’t find anything of note in there, but after a good clean it all seems to work again,
Thanks again – This forum has now stopped me from having to buy a new dishwasher and washing machine 🙂
January 16, 2009 at 9:57 am #274212iadom
Excellent news, you possibly dislodged whatever was jamming the pump impellor, even very small particles can stop it.
jim.
March 26, 2009 at 8:47 pm #274213rodge_the_bodge
iadom wrote:The good news is that what you have is actually a Bosch produced appliance, not the appalling Indesit rubbish now masquerading as Hotpoint.
Does this go for the micro filter set as well? I have a DWF34 which won’t clean properly and the micro mesh filter has become detached from the plastic frame.
The spares sites I’ve looked at have a range of prices from £40 to £65, but there’s a VERY similar-looking item from Bosch for £25. It all seems rather expensive for a piece of plastic but the manufacturers have got consumers over a barrel!
Is
http://cgi.ebay.co.uk/GENUINE-Dishwasher-MICRO-FILTER-MESH-HOTPOINT-1801754_W0QQitemZ350127653212QQcmdZViewItemQQptZUK_Home_Garden_Kitchen_Dishwashers_PP?hash=item350127653212&_trksid=p3286.c0.m14&_trkparms=72{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3A1686{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}7C66{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3A2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}7C65{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3A12{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}7C39{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3A1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}7C240{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3A1318
the same as
http://www.espares.co.uk/part/dishwashers/bosch/p/1083/856/0/0/973594/dishwasher-micro-filter.htmlGrateful for your expert opinion
March 26, 2009 at 11:21 pm #274214iadom
It should be the same part. 🙂
However, poor cleaning is usually due to clogged up internal pipework etc, this is caused by not rinsing the dishes properly before you load them into the machine.
This thread Bunged up Bosch of where to look for blockages.
March 27, 2009 at 10:56 am #274215rodge_the_bodge
I ordered the cheaper part and it was compatible though not fully identical in all respects. The dishwasher has been running for nearly 3 weeks now and is noticeably cleaner! The solution cost be less than £25 instead of potentially £60. Thanks Jim.
