Hotpoint DWF40
  • #58793
    Kez
    Been out to htp DWF40 salt indicator light flashing but have filled with salt any ideas please
    Thanks Kez
    #335704
    Re: Hotpoint DWF40
    Salt Refill Warning Indicator
    Situated on the console, indicates when illuminated that the salt container requires refilling. When the
    salt container is filled for the first time it requires 1.5 – 2.0 kg of salt to be added. The warning light
    will stay illuminated for the first 5 cycles after filling with salt. On the 6th cycle, the light will be
    extinguished.
    The control module counts the activation of the regeneration valve and after the end of the 29th cycle,
    the machine fills with water and turns on the warning light. The salt container then needs to
    be filled with 1.5 – 2 kg of salt. A further 600cc of water will then be displaced into the sump.
    This along with the previous water will close the pressure contacts. At the start of the next cycle, the
    module detects the pressure switch closure and switches off the salt indicator light.
    Note: If salt is added before the end of the 29th cycle, for example, at the 15th cycle, the indicator will
    be illuminated at the end of the 29th cycle. To overcome this situation, 2 litres of water should be
    poured into the dishwasher. This will close the pressure contacts and the control module will
    extinguish the indicator light the next time the machine is used.
    #335705
    Kez
    Re: Hotpoint DWF40
    thanks for the reply ,but this has come back ,advised customer to fill with salt and let it run for 6 washes but she has rang to say its still illuminated ,this dishwasher is a recon that we sold and has been standing for aprox 2 months in all other aspects it works fine .(customer had filled with 3kg of salt) am i looking at replacing the module to get the salt light to go out or are there any other possibilities thanks kez
    #335706
    Re: Hotpoint DWF40
    Its a pile of Indesit do do, the ‘other’ possibilities are endless. :rolls:
    Not come across that as a fault but most dishwashers in this area flash the salt light. The water is very soft so there is no need to add salt in the first place. 8)
    It does mention that you have to pour 2 litres of water into the machine to switch the light off if salt is added before the 29th cycle. :con:
