Hotpoint DWF40 – Prewash & Wash Error LEDs ?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint DWF40 – Prewash & Wash Error LEDs ?
  • #18558
    ChrisBrownUK
    Right on schedule (extended warranty ran out in April) our Hotpoint DWF40 has given up….
    Initially it stopped mid-cycle, and now flashes the first two LEDs (Prewash and Wash) regardless of the cycle I select (it waits for 3-4 minutes before the error). I’ve checked the filter, supply hose & drain hose for kinks & blockages etc and all look ok.
    Found a couple of old posts which mentioned the water level control, or base flooding. Pulled out the unit and tilted in all directions but no excess water came out.
    Any suggestions or information appreciated….
    #179443
    Re: Hotpoint DWF40 – Prewash & Wash Error LEDs ?
    First two lights flashing suggests a drain problem, could be blocked or jammed drain pump. Power off if you intend to investigate further.
    NB. Don’t attempt to unblock by forcing water back into the machine.
    #179444
    ChrisBrownUK
    Thanks for your suggestion (you were right!)
    Turns out a small fish/chickon bone had got through the filter and got stuck in the pump. A local engineer fixed it for a very reasonable £28. Lovely.
    #179445
    Thanks for letting us know the outcome, it is wise to rinse all dishes etc before putting them in the dishwasher.
    #179446
    ChrisBrownUK
    iadom wrote:… it is wise to rinse all dishes etc before putting them in the dishwasher.
    I’ve already given the wife a telling off! 😛
