Hotpoint DWF50 D/Wash – Heater
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint DWF50 D/Wash – Heater
  • #26361
    MickGeorge
    Hi Folks
    Been to this one today – blew fuse – cust replaced and blew three times :rolls: before m/c started and heater error code on.. checked out – earth fult and open circuit on heater.. checked board not signs of anything blown there..
    Not changed heater on one of these before so..
    1) Is this straight forward or are there any pointers anyone can give..
    2) Is there anything else likely to have blown other than board or am I safe in assuming all that most likely all thats required on this is the heater unit as the board looks ok…
    Any help appreciated.. thanks
    Mick
    #209832
    Re: Hotpoint DWF50 D/Wash – Heater
    MickGeorge wrote:1) Is this straight forward or are there any pointers anyone can give..
    Very straight forward, easy access having removed the R/H panel and lid.
    MickGeorge wrote:2) Is there anything else likely to have blown other than board or am I safe in assuming all that most likely all thats required on this is the heater unit as the board looks ok…
    This may be a worry….? 😕 You refer to it blowing a fuse “three times” now if by that you mean just the RCD tripped 3 times, that’s OK, but if you’re talking about 13amp cartridge fuses blowing, chances are that the board will be stuffed as well…? 😯
    #209833
    Alanj
    Mick,
    fitted two just last week, tip machine on it’s back remove clips from each side of heater.I replaced the clips that came off, with whirlpool jubilee clips, much easier.
    Alan
    #209834
    MickGeorge
    Thanks for advice guys..
    Was concerned about board as 3 x 13amp fuses replaced but board did look ok and not signs of anything blown.. did explain it was a posibility but thought bit difficult to test as m/c would only fill so far before pumping out so could not test for supply at heater to prove board ok..
    Unless anyone else knows different??
    Thanks for advice about fitting… have you a part no for the w/pool clips?
    Mick
    #209835
    MickGeorge
    Just looked on Connect for heater and it is comming up with 2 heater units..
    Anyone know the correct part no for this… Model DWF 50S.. ser no 21705944..
    Mick
    #209836
    Seamy
    Genuine Hotpoint Jubilee Clip for the job is part number:- HPT9900250
    Part number on heater in my van that i use is C00057684.
    You need 2 clips , but I keep a few of these as this heater job comes up often.
    I’ve found ordinary Jubilee clips are too thick & hose slips off unless these special jubilee clips are used.
    #209837
    petalpop
    out of intrest
    will it fit bosch/neff etc as well
    #209838
    Part No C00057684.
    Will not fit a
    Bosch petalpop, it is an Indesit made machine.
    Jim
    #209839
    MickGeorge
    Thanks for the replies folks.. 🙂
    Mick
