Hotpoint DWF50S dishwasher. 27700966 LS12 EVO 3.
No programme indicator lamps (left side of facia). All connections tight and clean, and no signs of burning on the main PCB. Small left side PCB holding the indicator LEDs is dead.
Machine can be programmed if you reset, then press the prog button and count the beeps. Customer said the dishwasher seems to work OK, but it’s a bit of a lottery getting the correct program.
I can’t decide which board is at fault; but for all the LEDs to fail simultaneously seems like a loss of power from the main PCB.
Any thoughts?
Steve.
