hotpoint DWF50 wont drain Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › hotpoint DWF50 wont drain This topic has 1 reply, 2 voices, and was last updated 20 years, 7 months ago by admin. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts August 29, 2005 at 12:05 am #11634 adminKeymaster Error code lights 3+4 flash. Made sure its not hooked up to hot water supply. Any ideas. Its only two weeks out of warrenty, typical 😥 August 29, 2005 at 10:29 am #146094 iadomModerator Re: hotpoint DWF50 wont drain Error 3+4 is either timeout draining or timer hardware version error. Could be blocked pump or hoses, or module fault. Not an easy pump to access, would suggest you try here. http://www.ukwhitegoods.co.uk/modules.p … whitegoods Please remove the plug if you are going to investigate further. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
