Hi can anybody help please. Having a problem with my Hotpoint dishwasher not completing the cycle. Stops undrained with lights 4&6 flashing. Cancel the program and restart and it then drains and refills . sometimes it starts to run and circulate the water and stops again with the same lights flashing or it fills and doesn’t circulate the water and a gurgling noise comes which seems to be the water being heated as the machine steams up and stops undrained. Then lights 3&4 flash which in the past have indicated a drain pump problem which i have rectified by replacing the drain pump. If i cancel and reset it drains so the drain pump works. Seems to me to be either the PCB or the circulation pump.
Can anyone confirm what the problem is please.
Thanks, Mike ?
