Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › hotpoint dwf61p – circulation pump slow
- This topic has 9 replies, 4 voices, and was last updated 19 years, 10 months ago by
stuffed.
June 19, 2006 at 3:33 pm #18573
stuffed
Participantcirculation pump seems to me to be slow, its not pumping much water through the rotating arms, ive checked
filters clean
water feed hose clean
can rotate pump by hand
i read about running on the starting windings in one of the posts, how can you tell if this is so.June 19, 2006 at 6:15 pm #179483Martin
ParticipantRe: hotpoint dwf61p – circulation pump slow
It’s more likely a water starvation/circulation problem and not a motor problem. If you fail to use salt in hard water area then that can cause problems with the instanteneous water heater and its control valve.
Time for expert intervention I would suggest (Click on link below) 😉
June 24, 2006 at 10:09 am #179484stuffed
stripped pump down and checked motor- thats ok , however white seven bladed rotor is very worn, with no points to physically connect it to blue plastic drive- can i get just this rotor
June 24, 2006 at 10:55 am #179485Dave_Conway
stuffed wrote:can i get just this rotor
Yep, you can 🙂
I’ll need the serial number to identify though as there were two different circulation motors used on this model.
June 24, 2006 at 12:51 pm #179486stuffed
the no on motor is 5600.031929 / isol.kl.f / mo1757/230-240v does that look right
June 24, 2006 at 2:25 pm #179487Penguin45
Dave will need the one from the rating plate of the appliance, not the motor code.
Penguin45.June 24, 2006 at 5:53 pm #179488stuffed
nos i have are
dwf61p/07
79700434
fd80093023type 59e71h
1000710220898390233June 25, 2006 at 7:01 am #179489Martin
1801737 is the part number for a replacement Impellor Kit in this case 😉
June 25, 2006 at 9:11 am #179490Dave_Conway
Blimey, not cheap is it 😯
£44.38 ex VAT and carriage, an email to spares@ukwhitegoods.co.uk please if required 🙂
June 28, 2006 at 7:45 pm #179491stuffed
holding fire on the impellor for the moment,
as I have already rebuilt existing – it basically a domestic heating pump impellor. only meant to be temporary job tho, and all is nearly fine except timing as shown on display . originally after fault whatever program selected – it said ( apart from cold prewash) 2hrs to go. now quick wash says 29 mins to go ( as it used to before fault), is the machine clever, ie is it learning as it goes .PS as a heating engineer i have to take boilers and sometimes houses apart to fit things and its a damm site easier than this – my hats off to you if you do it for a living
