Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint DWF70 despair
- This topic has 11 replies, 6 voices, and was last updated 19 years, 1 month ago by
Martin.
February 13, 2007 at 2:31 pm #25019
ParticipantOh what joy to discover my customer has a Hotpoint DWF70S dishwasher that’s displaying “AL05”? 🙁
Thumbing through my UKW Known Error Codes booklet (like you do) and it tells me “Circulating Pump fault?” Delving into the gubbin’s and slapping a meter on the motor (and its attendant water point device) makes me think the motor is OK. It’s clean, unmarked and spins easily by hand, no problem. 😕
So, not sure what to recon? Buying a motor and sticking it in is one sure fire way of confirming whether or not the error code is correct? But I’m not wasting my time and money speculating on this heap in tin junk. :rolls:
Maybe its the module? Dunno?
All I know is that it fills OK then pumps straight out and flashes AL05 and as to what point the motor should kick in, I have no idea? Service manuals cost around £20 per model from Indesit these days and therefore never a viable option. I doubt a manual would give much clue on this anyway?
I expect the Hotpoint whiz kids amongst us can bail me out here, any clues guys??….PLEASE 🙂
February 13, 2007 at 3:33 pm #204245iadom
ModeratorRe: Hotpoint DWF70 despair
AL05 Can also be Filters blocked.
Possible causes, Mesh plate, filter or microfilter, pressure sensor.
(Apparently) 😥
February 13, 2007 at 5:55 pm #204246johnnyj
ParticipantRe: Hotpoint DWF70 despair
Check the pressure hose i’ve had a few with water trapped up it causing an airlock.
February 13, 2007 at 7:46 pm #204247HotDog
ALO5 filter/p/switch/spray arm blocked loss of pressure
February 14, 2007 at 8:29 am #204248Martin
I’ve removed the filters, blown through the pressure hose and manually operated the pressure switch. The machine fills just fine (to the expected level) then immediately drains away with AL05 showing. 😕
Then why does the ‘known error codes’ state it is a circulating pump fault I wonder? 😕 😕 😕
February 14, 2007 at 9:49 am #204249iadom
The manual lists AL05 twice, once for each fault. ❓
The ‘pressure sensor’ is that small doofer just above the circ pump, not the pressure switch.
February 14, 2007 at 12:59 pm #204250Martin
iadom wrote:The ‘pressure sensor’ is that small doofer just above the circ pump, not the pressure switch.
Ah, gotcha, I can see that now, thanks Jim. Although, that looks like a flow sensing microswitch that comes into play once circulating pump fires up? In my case the motor don’t do ziltch, so maybe the doofer isn’t the culprit? 😕
February 14, 2007 at 5:43 pm #204251gazza57
hi, If fills and then aborts with drain pump worth checking its not siphoning.
Check heater insulation and high pressure sensor (the small one on circ pump, should be n/c.
If all is ok then module fault.
regards gazzaFebruary 14, 2007 at 6:44 pm #204252HotDog
Heaters can cause many false error codes check make of heater if its made by Irca i would be replacing first also i have changed a few of these motors and they all looked like new these part are worth having in stock tha hast speculate to accumalate trust me you will use these parts on other job if not on this call
February 15, 2007 at 9:12 am #204253Martin
Thanks Gazza and Hotdog, so its either the Heater, the Module or the Motor? Brilliant…these error codes are priceless aren’t they? :rolls:
I’m afraid I cannot justify speculating on which part may be at fault, wasting my time and my customers money on a guessing game. And quoting to fit all 3 parts on an either/or basis is very unprofessional. 🙁
It’s yet another case of “It’s 3 years old lady, so chuck it in the bin!”
(And in case you were wondering, the lady just moved into the house and the dishwasher was part of the ‘fixture & fittings’ so that the 5 year parts warranty route is a no no!)
February 15, 2007 at 8:18 pm #204254HotDog
Just another day in the life as as a service engineer thats one of the reasons why i specialise in hotpoint/creda i can stock all parts whith no fear of being stuck with unused spares sorry i could not be more positive better luck next time eh 😥
February 17, 2007 at 2:49 pm #204255Alanj
Martin,
as far as I’m aware the 5 year warranty should not be affected just because there is a change of customer. It is a 5 year warranty on the appliance.
Alan
